Advice on exhaust tips needed
b7gud911
Can any of you kindly chaps tell me how difficult it is to fit new exhaust tips to my Targa and if there are any i should avoid, stupid question from a simple paint sprayer but are they all weld on, i have seen some on Design 911 website in a polished diamond black that i like.
No the tips are not weld on they are bolt on and the bolts often corrode--normal practice is to cut the bolts with an angle grinder and replace them. In terms of what to avoid--the tips for turbo's and S cars are slightly offset--so avoid these for your targa.
Hope this helps
Steve
I agree with Steve suggest using a Dremmel type device with a few cutoff wheels (you will go through them) you can get into cutting the bolts easier. I have just done the same to my car and it took me about 20mins each. If you damage the clamps they cost about £19.12 each - code P928.111.427.00
They also have a type of metal washer that connects between the exhaust and the tips don't forget it as it does get stuck.
Ron
