Hi all. I’m after a bit of advice on topping up oil. I’ve a 2021 718 Cayman GTS that’s done 4200.
The other day the Minimum Oil Level warning came up and the oil measurement showed yellow at the min level and "Max 1.0 l to refill oil. Pos to drive on”. It also said it needed an oil service.
After looking on line and speaking to Porsche the recommendation was to add 500-750ml which I’ve done, adding 500ml. This has cleared the warning message and reset the oil service interval to next December, but the oil measurement is still showing the same.
It’s now booked to go into Porsche on the 24th December but any advice/thought appreciated.
Kerry
Kerry
