Hi all
advice please- the 'S' decal on the rear of the GTS has become partially detached with a very fine crease putting putting it away from the paint surface.
i tried carefully masking around it and re gluing the bottom leg of the S which is loose with the strongest glue I have - a two part epoxy . However even leaving for an hour or so the glue had not adhered to the paint clear coat so no good (was able to remive glue without leaving a trace)
- any suggestions? I looked on porscheshop website and they list images for panamera S decal and cayenne S decal at £30 ish but I don't know whether these are the same size as the 911 GTS decal? They don't list a 911 GTS decal.
- car is in OPC for major service next week so will ask them but don't know if they can fix or would do single letter replacement?
any ideas
thanks
any ideas
thanks
