Advise on brake pads/disks?
- Thread starter julianm
When you have ascertained what is wrong and what (if anything) needs replacing, do a search on here for good brands to buy. Zimmerman disks are generally unpopular, pads are a matter of personal preference.
chrisg
The reason I say this, is that its highly proabable you've glazed either or both by subjecting them to high temperatures at Brands Hatch. Brands is a short (relatively speaking track) with only two short straights for the brakes to cool.
I had a test session in a race car once where the front pads/disks got so glazed from heat and overuse that to get the car to stop I was putting so much force through the pedal that it was locking the rear wheels..... At the time we were convinced there was a handling/ brake bias issue !
Chris
morris944s2john
sawood12
Super_Marv
You can't get any better than the standard Porsche brake discs, in my opinion. If you do alot of trackdays, then it is worth trying trackday orientated pads and better brake fluid.
Northern924
The Porsche ones are very good, but if you are planning more track days you could look for ones that are designed for duel use to reduce the glazing.
Also the squeaking could be coming from between the caliper and pad, a light smear of copper slip will reduce it, just make sure it gets nowhere near the pad material or disc!!!
