Aerial location?
- Thread starter 964rh
Dave Wilkinson
The aerial is in the windscreen. I think the signal amplifier is under the dash but I wouldn't swear to it.
I believe the connection to the screen element is located immediately in front of the driver but I suspect it's not easy to get to without removing the screen. That cable should go to the amplifier and then from the amp to the radio itself.
I have a feeling there are some differences between LHD and RHD locations and also year on year changes too so I'm pushed to help any more I'm afraid.
Dave
964rh
Found out that the Aerial booster box is infact on the r/h side of the car, behind the clock. You have to remove the dashtop and clock to gain enough room to remove.
Also, ordered a new booster to head unit lead from local OPC. Porsche have changed the attachments on the lead and not the box (which is soldered) so I had to get the new lead soldered on.
Rob
