AbdnCaymanS
Hiya, I have just recently picked up a new Cayman S with the aerokit fitted. Looks great you're right! Ground clearance.. I'd say yes, it's a bit lower but I have been negotiating speed bumps etc alright, and the only things that have scraped a bit on ramps and things till now, are the rubber aero flaps ahead of the front tyres. Not really, an issue, as long as you remember you are driving a sports car, and not a normal family wagon, you should be fine. If it has the PASM it will be a little lower again (10mm), or if you have it lowered over standard, then yes maybe could be a problem more often. A friend has a lowered C4S and he has to be V careful which roads he uses, and even going in and out of his own back lane !
N
