plhorner
Moderator
Having had AFM problems over the summer which resulted in the meter being sent away for testing, I need to get my AFR set-up again as the adjuster screw was removed at some point during the testing. Fortunately I managed to measure the position of the screw prior to the meter being sent away and have re-set it to this position, the car runs fine. The problem is that it all kicked off when we were trying to adjust the set-up after fitting the SSI's, should I be looking at about 0.9 at tickover? Really ought to get it on the rolling road but time and funds really don't allow this year.
Cheers,
Cheers,
