Hello everyone, I hope all is well.
I have recently had my old becker replaced with a nice new Pioneer car-play 2 din unit.
My car is a 996 C4S 2004 with a Bose MOST system.
The installer has fitted the system keeping the Bose AMP in place.
And on setting up the radio I find I don't have fader control. I reached out to the installer and his response is below:-
[style="background-color: #ffff00;"]"All the companies we use in the UK do not do a harness that will convert an analogue 4 channel audio signal to MOST fibre optic as it is not possible. If you have spoken to other people and they have it working please double check there BOSE amp is fibre optic not analogue as the older 996 911 used a non-fibre optic amp. We have fitted stereos to a ridiculous amount of Porsches over the years and have never come across a lead that will convert a front and rear analogue signal to Most fibre optic. If you can source one then we can have a look at it for you and get this installed but as far as we are aware there isn’t one available."[/style]
If anyone has had a same/similar install to a same/similar spec car do they also have this limitation?
Regards,
Nozer
Regards,
Nozer
