tartan_rob
So I have a done a pile of work on the engine:
New:
- Big end shells
- OPR valve
- Alternator
- Oil pressure sender
Cleaned and brought back to new:
- Injectors
- All hydraulic valves (complete strip down and re-build)
- Intake system
- Cold start valve
Finally got her back together and she won't start. I broke into the fuel lines in the engine bay and there is no fuel at the engine, the lines are bone dry. I have half a tank of fuel (fresh today). I have almost flattened the battery...
The car was running before I started the work. One point to note, when I switch the ignition on there is the usual relays clicks etc but no fuel pump noise.
Any thoughts? Can I test the pump or the DME relay?
Thanks,
Rob
New:
- Big end shells
- OPR valve
- Alternator
- Injectors
- Intake system
- Cold start valve
Thanks,
Rob
