After switch-off noises
- Thread starter Guest
You might be hearing the turbo pump. This pumps water around the turbo body after switch off for about 30 seconds to reduce the chance of oil evaporating in the turbo bearings.
The exhaust will click as it cools down as well.
peanut
ORIGINAL: Diver944
This may sound odd but try cleaning the contacts on the switches in the door jams. It is common for them to fur up and not make a solid connection causing relays to 'click about a bit' - technical term []
thats what it sounds like to me too . Might be due to all this rain we have been having
Oh good! I thought I was alone with this problem ... they really Do click, don't they? Almost buzz, from time to time ...ORIGINAL: Diver944
Diver944
ORIGINAL: zcacogp
For many years I thought it was the internal alarm sensors detecting me moving about when the alarm was deactivated. Doh!
At least you didn't go looking for the relay that was being activated by the sensors unlike some people on here :whistles:ORIGINAL: Diver944
