HELP, PLEASE! I have a 1991-H 944S2 which runs fine when cold, however, the same can not be said after its warmed up. It does not idle steadily, and can in the worst case cycle between about zero and 3000rpm when you are stationary. The result of this is that more or less every time you approach standstill, it cuts out (this can be up to about 15 times in a 10 mile journey - can sometimes beavoided if you put your foot on the accelerator whilst stopping, but this is rather tricky!). It does, however, always start again, and once you are at driving speed, it is absolutely fine (i.e. it has never cut out when driving along). My initial guess was that it was the "˜idle adjust unit', however, I have since been told that this can be ruled out on the grounds that this unit only operates at revs up to 1500rpm. Any ideas??!!
