While I was fixing an oil leak (new oil cooler lines £££) I found a coolant drip which I've finally traced to the water pump. With the system under pressure it's weeping out from under the pulley (plus a separate drip from the radiator).
I fitted a brand new Laso water pump 3 1/2 years ago, so this is a bit of a surprise. Belts were tensioned as per the factory procedure with the tool. I can only think I made a mistake and got them too tight (perhaps the engine was too cold, I did it in a shed in the middle of winter).
So I don't think any choice but to do the water pump again.
