air and vent control
- Thread starter Guest
I have been following this thread and if you need to get at the fresh air blower for further examination it is very easy to access. I replaced my blower motor and fan housing complete in an afternoon. First remove the carpet under the bonnet to access the bulkhead cover by the master cylinder, this bulkhead cover spans the width of the car. Remove the bulkhead cover to access the fan assembly. When removing the fan assembly mark the wire cable that attach to the levers so that thay can be easily reconnected in the same position.
Hope this helps
John
Col
