Air con delete
944Scott
I have removed the compressor and I have the non air con bracket, does anybody know whether I will be able to unbolt the alternator and move it out the way enough to swap the brackets over? I really don't want to drain the cooling system.
I did this a few weeks ago on a turbo engine. I was able to get the alternator out and swap the mount without removing any hoses.
It's worth noting - if you didn't already know, that the bolt hole is different between air con and non air con that holds the alternator on. I drilled the non air con mount out for easy but you'll need to make sure it is level when drilling.
You can get the alternator out without draining coolant. It's a bit fiddly but do-able. I found unbolting the right hand side of the metal coolant pipe (2 x 10mm I think) gave a bit more wiggle room.
Stuart
