ORIGINAL: Tony M
100% Correct. If it a'int broke don't fix it !
A sealed system be it in a car, fridge, freezer, industrial, commercial, or domestic system does not need the Refrigeration system 'Serviced' because it is sealed.
A fridge freezer has about as much in common with a car air conditioning system as a nuclear warhead has to do with a nuclear power station.
A fridge freezer compressor is a simple device working much in the same was as a audio speaker works.
A automotive air conditioning compressor is a rotary device with mechanical wearing components lubricated with PAG oil.
The PAG oil is there not only to lubricate the compressor, but also to keep debris from wear etc in suspension within the oil, while also cleaning this debris from the compressor.
If you do not change the PAG oil, the contamination of the oil just increases, which increases the rate of wear within the compressor. Thereofre, an air conditioning service is there to replace this oil and get the contamination out of the system.
Likewise, as the quantity of gas within the system drops, the compressor has to work harder to build up pressure to the point where the gas will change state between liquids to gas and cause the cooling effect. Which again causes wear and increased fuel consumption. Unfortunately the 996 has no air conditioning pressure display to warn the driver of this, therefore a service of the air conditioning is to keep the gas level at the correct level and therefore reduce the stress on the compressor and engine driving it.
Seeing as you like to make comparisons to domestic situations. Think of a light bulb for a moment, we change light bulbs once they blow, we do this because they cost a couple of pounds and cause no damage when they eventually fail.
Now imagine that light bulbs had been found to typically blow at some point after two years, and yet imagine they still only cost a couple of pounds, but can cause a thousand pounds worth of damage if they failed.. I bet if this was the situation you would change your light bulbs every couple of years as a precaution.
In this example the cheap light bulbs are like the relatively cheap gas and PAG oil and the thousand pounds worth of damage is like the costs of a failed compressor.
If you buy a new 996/997 couple of years, maybe every four years, you will probably never have your air conditioning serviced because you do not think its needed, and you may not ever suffer a serious failure. But I bet later owners of the cars you leave behind you will not thank you for not having the air conditioning serviced when their compressor fails.
On the other hand, there is also another factor with air conditioning servicing. If you sell your car and in the history it shows that you have invested every couple of years having your air conditioning serviced, do you not think that sends a strong positive message to that future owner that you have been a careful owner who has pampered the car. I think it does.
Everyone has a right to an opinion, but the dangerous thing with the internet is that readers may take it as gospel. You think I and the company I used to work for (europes largest air conditioning manufacturer) are wrong regarding servicing. The thing is, my advice will certainly not cause any damage (in my opinion it will prevent it) your advice on the other hand could cause damage and certainly can not benefit as it advises no preventative action.
There are probably people out there on the internet who once had a old ford cortina for a few years and never changed its oil, they probably tell people about it and say it never missed a beat and went on until they sold it. Does their experiences constitute good advice?
Would you advise someone does not change their brake fluid, engine oil, transmission oil, coolant, power steering fluid? Surely whenever you have had any of these changed the oil fluid was still servicable? would the engine have certainly blown up if you had not changed the oil?
