richardm
Have been really enjoying the recent weather with the roof down in my 986.
However the air con when set on Low, pushes out warmish air. I have checked and cleaned the front rads Etc., and after seeing other posts about Kwik Fit air con services took my pride and joy along for a re-gas. They checked the system first and thought it was all ok, then started filling it, only to find fluid was leaking from a joint below the driver’s door. They said there was some green dye in there indicating checks had been made before perhaps. The good thing is that they don’t charge if it doesn’t work (normally £59.95)
Apparently there are two pipes side by side and it could be just a O ring at that joint...
Does anyone have any experience of this particular area? ??
