Thanks for the comments, new to this sort of communication!
As Andy kindly points out that the condensers are prone to corrosion and probably made of aluminium for lightness. I guess they would not corrode if copper like many radiators.
I am intending to strip the front down when the inevitable colder weather arrives, at the moment its really warm and the aircon would not be used with the top down.
I picked up a condenser from Europarts for under £50 which is very different from the ones quoted from Porsche centres.
They are probably built in the same factory but with the 'badge' attached warrant a four fold price hike.
So as suggested, strip the system, replace faulty condenser/s and o rings, etc and re-gass at £35 from FastFit shops!
It will be a few week yet but armed with the ability to do it myself should save a packet!
I will come back and advise.
Whilst chatting, I had another problem that I hope to have now fixed.
The warning light came on the dash suggesting an engine problem.
Having already spent £120, after purchasing the car, having the car checked by a local specialist with no errors showing, and a suggested further £60 to advise on the latest warning, I bought a POR11 diagnostic tool.
It advised that both engine banks were running rich at idle, I had experienced a couple of instances of stalling when at low revs suggesting a mixture issue.
When starting it sounded rough and smoke was issuing from the exhaust.
Being both banks it seemed it might be an issue before the combustion chambers, not plugs, etc, so I researched and someone suggested the filler cap could be leaking and allowing the car to run rich.
Replaced the filler cap and bingo, started straight away and no smoke or irregular running.
The cost, £8, bit different to the £60 to investigate!
Are we being ripped off?
I know of the saying that if you can afford a luxury car then you need to be able to pay for its servicing but £65 per hour compared to £35-40 seems a bit of a rip off! IMHO.
My local Wheel & Tyre depot fitted discs, pads and hand brake shoes in 3 hours for £120, again the service centre wanted £250!
Thanks for the support from members and user groups.
I guess this is why 70% of Porsche cars are still running, being maintained by motoring enthusiasts.
Jeff C.
