Air con question
Hi Guys,
My air con currently does not work - not investigated what the problem is exactly (it would be too easy if its just simply re-gas required!), but wanted to ask if it is a particularly effective system when working properly?
Just don't want to go through all of the hassle of fixing it if it's not very good...
Thanks,
Rohan
If you expect it to perform with the smoothness of a modern air con then you are likely to be disappointed. I hardly ever use it in the S2, just the vital minimum to keep it functional, but I loathe how it robs power from the engine. When switching it on at speed it feels like a parachute brake. When the compressor clutch engages, the engine vibrates so much it's embarassing. I'm glad I got rid of it on the turbo while there was no engine in it. To cut short, it's rubbish. In my opinion.
ORIGINAL: barks944 I wonder how easy it would be to swap the compressor over for a more modern one?
I believe Coolit do it as aftermarket fitment/cheap fix option anyway.
Seems reasonably effective on my S2; as effective as the system on my Golf IV anyway. There's a bit of a whine/moan from the compressor clutch at specific RPM but that's transitory. At idle speeds the only noticeable difference is increased noise from the cooling fan. At road speeds I haven't noticed any significant power drop from having it running.
