Does anyone have a wiring diagram that shows how the two Air Con relays should be wired above the passenger footwell. Or the configuration of wires on the rear of the dash control module.
I've had a mobile technician round to see why the A/C's not working and apart from not having a full charge of gas he thinks the relays are wired wrong and can't think how it ever worked. I assume it must have once!
Result is he's gone away to look for wiring diagrams and has left the relays and wires disconnected for the moment. He's tried all combinations trying to make sense of it, but there doesn't seem to be a switched feed to energise the relays. Also one of the relays seemed to be getting a live feed to both sides?
By bridging contacts we have proved the compressor swiches in and the condensor fan runs.
The sytem is a Diavia which was fitted in 97 with I think a 993 dash control unit.
There is also a mod that appears to have been made to the connector on the back of the control module where an additional (green) wire has been added to one end of the connector and evidence of one which has been removed leaving the terminal behind as evidence.
I realise I've not been very clear, but does anyone have any A/C info they think might help please?
Bob.
Bob.
