air conditioning compressor
Simon P
Hi, grateful for any advice about air con compressor for 993 C2. Sounds like the bearing(s) are starting to go as I get an intermittant growling noise from the unit when it is on. Stops immediately I switch the air con off. Are these units horrendously expensive and is there a decent second hand source? Or am I misdiagnosing?? Hope so !!
Simon
unit is nippondenso 10pa 15, if you are familiar with DIY's, I took this kit and it is working silently since.
http://www.acsource.com/index.asp?PageAction=VIEWPROD&ProdID=100
there are several kits available, and prepare your DIY through googling the name , regards
