Air conditioning
- Thread starter cmr777
You will be looking at the £400 - 450 mark to get that sorted.
I use Motortune in Shotts - Peter definitely knows his stuff.....
porsche 944s2 radiator
Elliot Davies
IMO not worth looking for a repair as if it goes again shortly afterwards etc.........
Just replace them and then a regas is around £500 and then make sure you clean the vents regularly to remove fag packets, leaves etc
Chris.
ORIGINAL: elliotw
In the winter months I didn't use my air con.
A common mistake to make Elliot. It's important to use the aircon in the winter too; there's a lubricant included with the refrigerant which lubricates the compressor and also stops the O-ring seals from drying out.
As Chris says, the aircon is very useful in damp weather to prevent the interior from misting up (common in soft-tops) by removing water from the air.
I seem to recall someone posting recently on the forum quoting a similar figure for condenser replacement. Personally, I'd replace both condensers if that is indeed the problem. Normally a dye is introduced into the refrigerant when recharging the system which fluoresces under ultraviolet light and helps identify points of leakage.
Jeff
On second thoughts, I think I may have been using the air conditioning during the winter. I was thinking that if I used the fan on warm (which I have during the winter months) it wasn't using the air con, but I actually think it does unless I manually press the air con off button (which I don't press). So I guess at least I have been using the air con over the winter when I thought I wasn't, right? Guess I naively associate air con with cooling a room, but if I am not mistaken, a car can be warmed up using the air conditioning system, correct?
Jonathan G
or alternatively, http://www.bestpartstore.co.uk/2757061
Bestpartstore seems to be pretty cheap for a single condenser. Not sure if I need the other bits n pieces in the Design911 kit - if not, Bestpartstore comes in much cheaper and can just order 2 condensers from them. Always can order the O-rings and dessicator from design911 to build my own kit cheaper than at design 911.
thoughts?
Need to take front bumper off - just screwed on, needs two people to hold either end to manipulate it off, once off its just a matter of removing the plastic cowlings around the radiators/condensors and splitting the condensors from the radiators (screw and some clips) cant remember exactly as it was 8 years ago when i last did a Boxster, couple of bolts that hold the air con pipes to condensor connections and two "O" rings in these joints, do both sides and rebuild.
should be done in a day even if youve not done it before.
saynotolettuce
