is this what you are looking for?
911
Door Panel - Air Leak
1/97
7059
10/21/97
Binder-Service Technical Bulletins
Air Leak at the Door Panel
Vehicle Type:
911 Carrera (964 and 993)
911 Turbo (964 and 993)
Model Year:
As of Model Year 1989
Concern:
Air drafts in the area of the inner door opener.
Modification:
As of April 1, 1997 from VIN: 99 1VS322950
From the above-mentioned VIN a felt piece is installed in the inner door opener (Figure 1). This significantly reduces air drafts from the area of the inner door opener. The felt piece may be installed in earlier vehicles.
Repairs:
Installation of felt piece.
- Disconnect the door opener rod, inner door cover and pull handle.
- Lay felt piece onto the inside of the inner door opener, and mark with a pen or suitable marker (Figure 1).
Important : The pointed part of the felt piece must point forward in the driving direction.
- Apply glue on the marked area of the inner door panel and install the felt piece.
- Reinstall the pull handle, inner door cover, and the door opener rod.
Important : Avoid damaging the felt piece by carefully pushing the door opener rod through the slot in the felt (Figure 1, arrow).
Parts:
993 555 715 00 Felt
