Air oil separator replacement 996 c4s
- Thread starter rodneyhj
richardjjs1
Have you bought 101 Projects for you Porsche Carrera its a must - covers this .
you need a new hose clamp as well
If I remember the problem is getting at the clips at the bottom of the separator
Reasonably easy on the Boxster but not so easy on a 996
£57.30 + VAT (Less Porsche club discount)
richardjjs1
Don't even think about doing it yourself at 3/4 hour labour
Good luck
rodneyhynejones said:Thanks. So I gathered. I've been quoted 3/4 hrs labour
richardjjs1
Just got hold of a copy - really good, thanks.richardjjs1 said:Your biggest problem is access
Where did you get that quote as PC Colchester quoted £80.08 + VAT?
Pete Ansbro said:………….. My indy wished he'd lowered the engine …………..
That's what PC Bolton did when replaced my AOS when I had my 996.
richardjjs1
richardjjs1
It is a tricky job with the snap clip and bellows at the base of the AOS. I also had problems getting the upper connector free from the block - the o-seal seemed to have welded itself, as it should just pull off.
On the plus my engine feels great and idles smoothly.
