Air sampling pipe
I thought that might be it, which means I can't help. I do have some of the diagnostic pipes from the engine bay and was just checking in case you meant one of them.
Geit it replaced though as it will make the heater work. When I found a crimped vacuum line in the blower assembly in mine (while changing the wiper linkage) and fixed that mine would pretty much hold a pleasant temperature roof up or down without touching the dial.
I think I have one being posted tomorrow & am hopeing that the temperature will be a little better once the sampling system is closed again.
