Hi
2010 Cayman S- the airbag light is on, also the PCM is dead (the PCM died first)
Run a diagnostic - and I get error 80 CB Trigger unit faulty - which I assume is the airbag control unit - does anyone know where this is located - so I can inspect wiring - also if I get a replacement unit will it need coding to the car or is it a straight swap? I tried clearing the code but was not successful.
I am not worried about the PCM as I may replace it with a dynavi unit or leave it out to save weight - but are these faults related potentially ?
I removed the PCM, and tried clearing the code as well, which was unsuccessful.
I also have a loop cable on order for when the radio is not in, to see if that helps on trouble shooting.
TIA
TIA
