Airbox
Logie
Anyone done any successfull mods to the airbox? It looks awefully restricted.
Just wonderd if another cold air feed from the front into the airbox would work well. Sure mine has a performance panel filter already...
I've modified my air box very succesfully...........
I threw it away [:D]
ORIGINAL: wizard
John - Is it possible to configure the air filter to your position with the standard AFM fitted?
I don't believe it would be because the air flow meter is too bulky. I am using MAP so don't have an air flow meter at all.
I suspect as long as you have an AFM the most restrictive element in your whole intake system is likely to be the AFM. If you were to upgrade to MAF or MAP then it would be worth thinking again about your airbox.
The beauty of the airbox is that it takes in cold air from outside the engine bay. I reckon even with a cone filter behind the passenger light you are still sucking in warm air.
