Aircon Glasgow
Paul Fraser
Anyone have a rec for an aircon specialist in Glasgow (preferably mobile). Am curently in process of replacing _both_ pipes under Boxster (one was leaking, and, of course, I thought it was the other one...) and am also going to do both of the aircon radiators. Need someone to pressure test, flush and then fill system. Cheers.
Used this place a year or so ago
Airways[FONT=verdana,geneva"][FONT=verdana,geneva"]Huntershill Way, Bishopbriggs, Glasgow, Lanarkshire G64 1XP [FONT=verdana,geneva"]
Tel: 0141 772 3277 [FONT=verdana,geneva"][FONT=verdana,geneva"]
have used chap called mark henderson (autocool)
did the work on my ferrari 355 and actaully today just replaced the radiator on the aircon in the shogun,,
based stirling but works all over,,, does all Peters work at Motortune,,,,
phone 01324 815 525
mobile 07770 732 325
very reliable so far
cheers
scottie.
Just finished repacing the pipes, condensers and dessicator. The hour of reckoning is Friday lunchtimeish. Fingers crossed....
Well, he came today (Mark Henderson) and struck me as a top bloke. Knew his way around the car, very knowledgeable and I talked the hind legs off him. The plumbing I'd done on the Boxster seemed to have been done properly as it pressure tested ok. After that he vacuumed the system to get rid on the moisture and then circulated some oil round it the clean it before regassing. System works again! Hopefully, I'll still be saying the same in a few weeks.
Also found out that the self-regas kits I'd tried out on the 996 are not a good idea. On a system that is leaking, the sealant solidifies on contact with moisture and he knew of one guy who had wiped out his compressor (will find out if I have done any damage to mine next month when he comes back for that one).
Also knows his way around 928s as well. Highly recommended.
