The aircon on my 2006 2.7 Boxster 987 has stopped working and I'm told I need to replace both front coolant radiators. Does anyone know the part numbers and where is best place to get them from?
Aircon problem
- Thread starter amjconsult
Darren SCF777
Hi please see the link to the E987 katalog pdf would expect to find the parts numbers in here..
http://www.porsche.com/all/media/pdf/originalparts/en/E_987_KATALOG.pdf
John Maddox
The problem with air con you fix one leak and then find there is another elsewhere. My previous 993 had about £3k of work done to aircon, under warranty luckily, before it worked properly.
My current Cayman had various pipes changed under warranty again before it held pressure.
Make sure it is diagnosed properly, that's the key.
Yep, I replaced the front condensers on my car only to find the pipes that run to the pump from the rear wheel arch were leaking as well.
