airlock in water system
- Thread starter byron
Lever up the trim cover underneath the filler necks.
Flip up the coolant bleeder valve locking clip.
Replace the Oil filler cap
For automatic transmission cars, remove the fuse B1 in the fusebox "" this disables the shut off valve for the ATF cooler.
Fill with the 50-50 coolant-water mix. Fill to the Max line in the level indicator.
Run the engine at idle, continue to top off the coolant until no more can be added.
Do not allow the coolant to exceed 80 Degrees C (176F).
Replace the coolant cap and tighten. Let the engine warm for 10 or so minutes at 2500rpm. When the engine is fully warmed up the radiator cooling fans will come on. Run a further 5 minutes at 2500rpm, and blip the throttle now and again to 5000 rpm.
Cover the coolant reservoir cap with a thick cloth and open slowly, releasing the pressure very carefully "" do not scald yourself!
Top up the coolant, close the cap again, and repeat the process for a further 5 minutes, revving intermittently to 5000 rpm.
Idle the engine until the radiator fans have cycled on and off once, then switch off the engine and again carefully remove the reservoir cap, taking care to relieve the pressure slowly.
Top up the coolant until it is at the MAX mark on the level indicator in the rear boot.
Flip the coolant bleeder valve locking clip down again.
Replace the filler neck trim cover and all caps.
Replace fuse B1 on automatic transmission cars.
You shouldn't mix coolants and Porsche don't seem to say what is in theirs so I'd get it from Porsche. If you buy elsewhere then make sure it is phosphate-free and silicate-free.
How much water have you used? If you drained the whole system then you need to replace it with the Porsche coolant.
I'd hate to tell you blucol is ok and then a seal gets eaten and you blame me [] Only you can decide what you put in.
The Porsche stuff needs to be installed as a 50-50 mix with water (unless it comes pre-mixed these days?). Depending on the model you have it has up to 22 litres of coolant in it - so that's possibly 11 litres of the Porsche coolant you need.
Edit: The posts below suggest it comes ready mixed now. I stand corrected.
Also - I wasn't stong enough in my recommendation - I'd buy the Porsche coolant. Why risk it unless you know for sure?
BartyB
