hi there everyone i am having a problem with my alarm it as just stoped working when i am pressing the button on the key the red light on the key is flashing and the red light on top of the dash is flashing red as well but its not doing anything and when i am pressing the boot and bonnet button on the key its not opening them either any one have any idea's thanks
alarm problem
- Thread starter byron
May have lost sync. Try this: 1. Switch on ignition with key 2. Switch off ignition with key 3. Remove key from ignition switch 4. Operate remote transmitter on key within 6 (six) seconds of removing key.
If the above doesn't work then try the key handover procedure: "Insert the key into the ignition lock and turn the ignition on. Then press the remote button until the blinking frequency rate of the central locking switch in the dashboard changes. Remove the key from the ignition lock and test function."
colinbythesea
It might just be wearing out. had to replace both of mine so far.
thanks for all your help i was thinking could it be the key fob it as been working fine but i noticed about three weeks ago it wasent working all the time and know its just stopped working all together like i said it will not even open the boot are bonnet with the key fob do you know how much a new key would cost and if i buy a new one will it work straight away or will i have to have it reset to work with the car thanks
Have you tried the above? If you buy a new fob you will have to get the Porsche Dealer to programme it to match your car. (So no, it won't just work).
you can still lock the car with the key in the drivers doorORIGINAL: byron hi mark yes i have tried all of the above i have been and got a new battery for the key fob and i will give it a go and if that doesn't work it looks like i need a new key fob the trouble is i cant go out in it as i cant lock it up but thanks for all your advice
DiamondDave944
This happened to my key (luckily for me it happened during the checks when I was picking the car up from the dealer). The dealer arranged to have a new key fob sent to me by Porsche Centre Colchester, It arrived about a week later with a receipt for £91. I had to take it to Porsche Centre Glasgow to have it programmed to the car and the bill for this was £59
thanks every one for all your help i will have to go and order a new key fob and let them program it in for me i can lock the drivers door with the key but it will not lock the passenger door so the passenger door is open at all times any idies on that one you lot must think i am a right pest
