MrMoots
Hi
I have a little issue with my 1998 C2 996 that is am hoping someone has as easy answer to.
I am aware the "sleep” mode the car goes into after 3-5days and I normally unlock the drivers door, put the key in the ignition, turn it on then the alarm stops.
Others with later cars appear to be able to wake the car by turning the door lock key anti-clockwise but mine has never done that so I assume being pre-2000 the alarm system Is slightly different.
The issue I have is that the car is in sleep mode and the drivers door handle has just broken. How do I get into the car without smashing the window?
There is no key lock on the passenger side and the passenger door remains locked!
I believe there is a emergency cable behind the front light unit to open the bonnet, but then what, is there a way to power up a circuit easily to either wake the car or operate the central locking, thus opening the passenger door?
From playing with it before I know that even with the alarm going off the car does not fully wake until the ignition is turned, so the bonnet pull handle dead bolt is still engaged and passenger door locked.
Any help much appreciated, I don't really want to smash a window.
Ross
Ross
