alarms
- Thread starter Guest
I believe the alarm fitted to your 996 is factory fitted and should also be category 1 Thatcham rated.
This information provided should normally be sufficient for the insurer.
If the alarm set/unset works from your Porsche Keyfob button, then it's almost certainly a factory fitted system.
I would call your nearest OPC just to confirm what I've said is correct.
They did not need confirmation once they realised this.
