Alloy dial bezels
- Thread starter 911SSC
ORIGINAL: 911SSC
Unfortunatly i have to do something as one of the dials has a dent where it looks like someone before i owned has prised the next dial out with a screwdriver []
Ian
Ian - Keep an eye on ebay. They come up all the time and will probably cost around the same as buying the bezels.
dugsud
bit more interest.
I also think the standard gear knob is a bit cheapo on SC's & 3.2's & and an alloy one looks nicer!
But hey....lots of people won't change a thing from the factory & if that's how you like it....thats cool [
911SSC
ORIGINAL: Jacob
I think it'a Matter of personal taste - do you like them?
I have a set and all the various other alloy bits you can get - I think they give a modern feel to an otherwise dull 80's interior.
Yes i do ,as you say it gives the car a but more of a modern feel.I have yet to see any with all the other alloy bits and bobs fitted ,do you have a picture so as i can see them please.
Ian
tail_heavy
A bit of a faff, but carefully prising it away from the dash using a wood spatula thing I snaffled from the kitchen did the job. Don't use a screwdriver.
Take care not to lever it against the dash covering as the vinyl marks easily. Once I had the clock out I stuck my hand through the hole and pushed each one out from the back. Just do one at a time and work you way along using the removed dial to access its neighbour.
Even taking care I still damaged one of the rubber sleeves which now bugs me. I would plan on replacing them all whilst you have the instruments out. Change the light bulbs too, they're cheap and I was amazed at how dull the old ones had become.
tail_heavy
