Alloy Wheel Refurbishment
- Thread starter RGL55
Alternatively, these guys will come to you http://www.exelwheels.co.uk/
I have used both and was very pleased with results.
Martin
924Srr27l
RGL55 said:Gentlemen,
Thanks for recommendations received, appreciated!. As I live only about 9 miles from Colchester will give Wheelworx a try.
Regards,
Graeme
Hi. just check and ask them if they Coat the back of the Hub mating surface, only all OE wheels from all Manufacturers are NOT coated because it not only causes wheel balance problems from irregular thickness but also with Heat it can relax and loosen the Wheel bolts / nuts!
So many places do this (Coat the hub) and it's not good.
Roger
