Johnny C
I had a high-pitched whine coming from the rear end (of the car not me) which I thought might be the clutch starting to die (it's got at least 50k on it). Well, it turned out not to be from the clutch. Main clue was a bang, a burst of smoke and the smell of burning rubber. A non-Porsche alternator belt had been slipping when I let the clutch out and basically melting, there are bits of melted rubber scattered around the engine compartment.
So a porsche one was fitted (at no cost). The bearing on the alternator seemed fine, but the squeak has returned when I'm dropping revs coming up to a junction and I accelerate quickly it if the traffic lights turn green. At least the belt is intact, it's due in for a service so will get the alternator checked out properly.
Has anyone else had a problem like this? Bearing runs fine when you turn it by hand, but for some reason when you're dropping revs then accelerate quickly it sticks?
