Alternator Belt Change
mcgc0
Had a dig around in both the Workshop Manual and Adrian Streather's book but can't seem to find any specific routine for changing over any of the belts (A/C less of an issue).
Anyone have any pointers?
The instructions are in your owners manual. Hopefully you have the splined tool in your car's toolkit which is needed to lock the alternator shaft while undoing the securing nut.
Take a note of the number of shims between each pulley half as you remove them as these are used to adjust the tension of the belts. Less shims = tighter. The unused shims are stored alternator side of the pulleys.
Also make sure you have 6 shims in total , if less you will need to replace the missing ones even if they are on the outside, as the the bolts expect 6 due to their thread depth..
Top replies guys - thanks. The Owners Manual was not one I checked (bit of an ambitious diy for the manual!)
Off to Le Mans tomorrow so just covering my bases just in case..
ORIGINAL: mcgc0
I think it's in there in case one snaps on a journey so that you can replace it. It's for that reason that I keep a couple of spares in the car. Have a good trip [:)]
