jboult
I can only reply from basic knowledge (owning a Land Rover will do that for you...), but the warning light circuit is usually very simple.       Ignition on feeds a +ve to one side of the light, the other is connected to the alternator output which, when not rotating, effectively gives a path to earth. Diodey stuff I guess. Anyway, this means the warning light comes on.       Once the engine is started, the alternator is rotating and the output matches the battery voltage, so there is +ve voltage on both sides of the lamp and no earth - hence it goes out.       I guess in a low alternator output situation it might still be enough to not have the lamp come on, although I've never had that happen to me. I'd expect it to glow a little, at least.      I'm sure you've checked, but just in case...      Does the lamp work at all? I don't know if it's necessary for the circuit in order to allow charging on a 993. I know it was required on my old Landy and without it, no charging. Easy enough to check as it will illuminate when you turn the ignition on.       Did you check the output from the alternator before starting the rebuild? I don't know offhand what it should be, but I'd assume anything around the 14V mark would indicate the alternator was working fine.      I'd have started by checking the alternator output (inc. at battery), battery earth, belt tension etc. before a rebuild. Caveat - I am not an auto-electrician!      Cheers/John
