H i, I have a 1991 944 S2, which has recently been giving some problems with the battery going flat after as little as a few days of being laid up. It starts ok if I jump start it, or remove and charge the battery. I reckon the battery is faulty (despite only being a year old!) as there is nothing draining it when the car is off. I checked this with a clamp type ammeter.
My concern is about the charging when the car is running. When it is running with no electrics on the voltage at the battery is 13.8 Volts, with 20 Amps. When all of the electrics are on full this drops to 12.8Volts and 3 Amps - is this normal. I think I can accept the current being lower at the battery under full load, but woul dhave thought the voltage would stay the same. Does this sound like a potential problem with the alternator or voltage regulator, and is replcing either of these especially difficult?
Any thoughts/ideas/suggestions would be greatly appreciated.
