Hi guys, On my way home last night I noticed that the dash voltmeter was only showing 12 V, but everything was running ok and no battery light so I carried on. By the time I got home (another 5 miles or so) it was reading only 11.5V. I turned off the ignition and then tried to restart with no joy only clicking so I put the battery on charge overnight.
This morning the battery is fully charged, showing 12.5V using a multimeter, (it was new 18 months ago) so started her up, no problem, voltage didn't drop below 10.5V on cranking so battery ok. Intially I got 14.4V charging at the battery then after a few seconds the voltage dropped steadily to 12V, I guess if I left it would have gone down to 11.5V as the day before.
Question-Is that just the voltage regulator backing up or the alternator? I'm going to take the alternator off anyway so I could get it checked I suppose, but don't want to be ripped off for a new unit if it's likely to be just the regulator.
I've read some other posts, but my problem seems slightly different. Thanks for any help.
Jon
Jon
