Alternator Replacement
sawood12
Anyone done this on a Turbo before? I've replaced alternators on other cars in the past and it's a quick and easy job, however on the Turbo there seems to be a hell of alot of pipework in the way which looks like it all needs removing to get access. Are any of these full of fluid (or air con gas) or are they all just air either going to or from the turbo?
Is it possible to carry out the replacement from underneath (the workshop manual say's not)?
Cheers.
Yeah, it is sort of involved. No aircon lines to remove but you must remove all the air intake plumbing over the top and there is a coolant line in the way so you will lose a little coolant, but not much, so don't drain the whole system.
I don't know how or why you would want to try and remove from the bottom as you would have to get the AC compressor out of the way. However, you will have to work from the bottom also to do this job.
Almost all the work for this job will be just getting to the alternator.
