Alternator /upgrade/exchange
- Thread starter C4ix
Kongsodoken
DarrylH said:I remember there being a Nissan one that fitted. I think it was mentioned on Rennlist
[link=http://rennlist.com/forums/944-turbo-and-turbo-s-forum/784458-944-turbo-nissan-alternator-mod-reposted-and-to-the-point.html]http://rennlist.com/forums/944-turbo-and-turbo-s-forum/784458-944-turbo-nissan-alternator-mod-reposted-and-to-the-point.html[/link]
Monkeythree
blade7
Well-known member
Monkeythree said:I have seen an "aircon delete" bracket marketed in a few places. Anyone know if this is any different from just fitting an OE alternator bracket from a non-aircon model? And is there any advantage over just removing the aircon compressor?
AFAIK the non aircon alternator bracket works fine and a used one is cheap.
Certainly though just relocating it frees up a lot of space around the compressor area!
944Scott
No that the bracket is heavy but I did notice a Lindsay racing air con delete bracket on ebay for £65 which looks like it would bit lighter if you are on a weight saving mission as well.
944Scott
Depending how much you intend on stripping down the engine to fit the bracket the rear bolt can be a PITA to remove.
C4ix
