BartyB
I had the car MoT tested yesterday and as I was putting the paperwork away last night noticed that the tester had entered the mileage spectacularly incorrectly. I then checked on the DVSA database which confirmed the incorrect mileage had indeed been recorded on their system. As these records are used by prospective buyers, HPI and insurance companies for checking annual mileages, it was of some concern that a staggering 530,000 miles had been added to the total mileage for the car in the last twelve months.
I've now checked with the dealership who acknowledged the error and advised that they would correct the database and issue a new MoT Certificate. My thought was that whilst this is fairly obvious that an additional digit had been entered into the system, it may have been less obvious if a couple of digits had been transposed.
On doing a bit of checking, it appears that if a tester enters the mileage (or body colour) incorrectly they can issue a replacement certificate provided it's within seven days of the test. If not, then it can only be corrected by applying for a new certificate through VOSA, in which case the original incorrectly recorded mileage will still be shown on the re-issued Certificate, alongside the correct amended mileage, which may cause issues at some point in the future. The lesson here is to always check that the mileage recorded on a new MoT Certificate is correct before you leave the Test Centre.
Just out of interest has anyone else had this problem?
