Hilux
Endeavouring to change the offside rear wheel bearing [
Clarkes Garage suggested that you dont need to remove the trailing arm to get the half shaft off.
You bl**dy well do as far as I am concerned as the gearbox oil cooler stops the transaxle end of the shaft dropping down and the gap between the aluminium cylinder against the spare wheel well (fuel filter?) and the gearbox oil cooler coil stops you lifting it up. [&:]
Or am I wrong? Anyone else changed a rear offside wheel bearing on a 1988+ turbo?
