And the big question for the weekend is...
No. There was a slight delay after the TiPEC day because the cold intake 'snorkel' actually stuck out about 50mm and fouled on the throttle. It was sent back to be machined back to 15mm which is all you need to get the hose and a clamp on there.
After that it did fit in okay but Jon was a bit worried about the clearance (or lack of) between it and the engine mount so a bit more 'fettling' had to be done. Last week he fitted and refitted the turbocharger about 20 times until he was happy, and as of Friday all that needed to be connected was the intake manifold, the new radiator and the associated plumbing. Then the car was ready to be started [:eek:]
......watch this space [:)]
If its not finished then if anyone local has a trailer I could bring it up for the weekend, (well if you call me within a couple of hours).
Tony
