peanut
put your thinking caps on fellas I need your help .I'm really missing my baby
I need a think tank with this problem.
HISTORY
My S2 hasn't started since September /Oct last year.Prior to that it was used regulary started instantly every time ran like a train and never once coughed spluttered or gave a single problem
Due to infrequent use in July August last year the last 2-3 times it was used it was very hard to start. It would take 3-4 minutes of continual cranking before it would fire on 2x cylinders then 3x and finally 4x cyclinders. I had to crank the engine with the starter all the time it was firing on 2-3 cylinders to keep it firing.
Finally it would have a bit of a cough and then run perfectly unless I left her for a couple of weeks then it would be the same problem starting again.
CHECKS
Battery is new and kept topped up
Earth straps are all new throughout the car
Plugs are new
Engine spins over really really fast like a dog shaking a bone
Spark at plugs
Fuel at injectors and in bores.
12v+ pulse at injectors
HISTORY
CHECKS
Plugs are new
Spark at plugs
