Fat Albert
Driving down to Bracknell from Huntingdon this morning and all was going swimmingly......
I flicked on the windscreen wipers, they wiped twice and then the drivers one stopped in the vertical position!
I stopped in a layby near St Albans (Thunking a kerb in the process[
]) and had a look and couldn't see what was wrong in the dark
I drove the remaining 60 miles with an opaque triangle in my main line of vision (I was able to reach out of the window and manually wipe some of the windscreen, and found that spraying the washers helped a bit...)
When I got to the office I took another look and found that the actuation arm has fallen off the motor shaft, I have put it back on, but should something hold it on as it will just fall off within seconds of being used?
Not looking forward to the journey 'ome....
