andrew_churcher
Hi All,
I need some help everyone. Appreciate your thoughts on the below
Q1:
Is this the correct checklist for an annual oil service for the 944 S2? My understanding is that this is basically the "6k service" as per the service book.
"¢ Check all Lights, levels, washers and wiper blades
"¢ Check all electrical devices
"¢ Lubricate locks and hinges
"¢ Change oil and filter
"¢ Check underside of vehicle for fluid leaks and rubbing
"¢ Check radiator vents for debris and remove
"¢ Check all brake and fuel lines, Tectyl all metal ones
"¢ Check drive shafts and CV boots
"¢ Check all suspension and steering joints
"¢ Check all tyres and do pressures
"¢ Test drive
Q2:
I have noticed the car intermittently (after I have driven the car for over 30mins) fails to idle as per usual when I have stopped (for 15 mins or so to go shopping etc) and then gone to restart the car. The car starts, it idles at about 200-300 rpm"¦.and then after a few seconds it kicks up to the normal smooth idle of approximately 900-1000 rpm. Its probably done this 4-5 times over the last 3 weeks (and it's the same thing each time..rough low idle) so any advice on what the problem is would be appreciated. After it hits the normal idle....the car drives fine....the car also starts and idles as per normal from cold....so the problem only seems to occur after the car is warm
Q3:
Is their any winter prep I should get done at this service? I was thinking to get the sills waxoiled to protect against rust etc"¦and even though I don't plan to run the car if the weather is beastly over winter "¦.I would still like to drive it as much as possible.
All assistance much appreciated
Rgds,
Q1:
"¢ Test drive
Q2:
Q3:
Rgds,
