Hi Folks,
I made some massive progress on the car over the weekend and almost killed myself yesterday pushing it out of the garage, turning it around, and pushing it back in the garage. I must have sweat a few gallons!
Now to start on the engine rebuild, I already sent away the throttle body to Simon at SPS and it came back looking better than new! He also kindly offered to answer any questions when I start with the build. I've also read David's and Stuart's rebuild stories, paying close attention to the details!
I hadn't originally intended to rebuild the engine, just change the clutch and fix the leak at the RMS whilst restoring the back end of the car.
However, upon removal of the clutch and flywheel I noticed that was what felt like a lot of movement in the crankshaft. I measured it with my not 100% accurate dial gauge at 0.8mm which is twice the allowed measurement in the workshop manual.
Before this the car ran OK and felt as fast as when I first got it in 2007, however I noticed that the oil consumption had increased (it had always had an appetite for oil however). I also have a feeling that I may have a head gasket leak as the coolant level does slowly drop with not much evidence of a leak. When I changed the oil after the car came out of storage in 2018 it came out looking like milky coffee, but I thought that it smelled of fuel more than coolant.
I will try and capture as many pictures as possible along the way.
The plan is to do as much of the work myself as possible and employ a machine shop to do the serious work.
Next task is to buy / borrow an engine removal crane, stand, and support beam. I'm going to try taking the engine out of the bottom (Clarkes garage says about 21" of clearance is needed to slide the engine out from underneath). If clearance is an issue, I can take the intake and fuel rail off beforehand.
![](http://i.imgur.com/RjkSzudl.jpg)
Emerging from the garage after hibernation for 2 years!
![](http://i.imgur.com/LwnwG9Jl.jpg)
After a quick clean, yes the rear looks high, the gearbox is currently in my utility room, so I'm hoping it sits right when that is back installed.
![](http://i.imgur.com/ptxw14xl.jpg)
Back in the garage, ready for the engine to come out.
![](http://i.imgur.com/MIu8k3Ql.jpg)
![](http://i.imgur.com/IjRRgOBl.jpg)
Rebuilt throttle body from Simon at SPS
