Still trying to sort a few little issues out. I have had the exhaust studs from the turbo replaced as one had snapped and the exhaust was blowing. But the car started what can only be described as missing badly. Euro and Porsche (who have been very good) found the TPS to be faulty as the car would run fine with it disconnected but would only boost to 1.2 on the gauge and idle at 1200rpm. I have today replaced the TPS and the car idles spot on and drives fine until you start really putting your foot down. Then it starts missing again but not aggressively more like the boost is on then off then on.
So my question:
Is it possible if the wastegate is old and worn out that it could have the above effect?
I was thinking it was electrical but if you make the car pull in a high gear from low revs i.e. its under very heavy load it doesn't miss, it only does in under high boost conditions.
So my question:
