Pickled Piper
I read a post on another forum that recommended that a disc and pad change should not be carried out simultaneously. Rather, the discs should first be changed retaining the old pads, then following a certain period of driving the new pads should be fitted. The rationale was based on preventing the pads/ discs from glazing and improving the bedding in procedure. Now, I've changed many pads and discs on several vehicles over the years. I've never come across this advice before. Is it total bunkum, as I suspect? Or is there some merit in using this procedure.
pp
pp
